Specialized Stumpjumper Comp 2007 (Nieuwe foto's !!! op p2)
- rexer
- Rijdt met: Specialized Stumpjumper
Vandaag eindelijk mene nieuwe mtb besteld bij de fietsenmaker
Zaterdag heb'k hem En dan zet ik er wel wat fotootjes bij
specificaties:
FRAME M4 alloy hardtail, fully manipulated DT, TT, SS, CS, ST w/ Mono-stay seatstays, ORE DT/TT, disc mount, replaceable derailer hanger
VORK Fox F90 RL 90mm, air spring, rebound/compression adj w/ lock out, alloy steerer
BALHOOFDSTEL 1 1/8" Threadless, alloy cups w/ 10mm insertion, sealed cartridge bearing
STUURNOK Specialized adjustable rise, OS 31.8, 3D forged w/CNC finish
STUUR Specialized XC flat 31.8mm OS bar, 2014 butted alloy, 5 degree backsweep, 600mm width
STUURLINT/HANDVATTEN Specialized MTB, dual density
VOORREM Avid Juicy 5, hydraulic disc, G2 Clean Sweep 160mm rotor
ACHTERREM Avid Juicy 5, hydraulic disc, G2 Clean Sweep 160mm rotor
REMHENDELS Avid Juicy 5
VOORDERAILLEUR Shimano M581 LX, 34.9mm clamp, bottom swing, dual pull
ACHTERDERAILLEUR SRAM X-9, 9-speed, long cage
SCHAKELHENDELS SRAM X-7, aluminum trigger 9-speed
CASSETTE / FREEWHEEL Shimano HG50, 9-speed, 11/34t
KETTING SRAM PC-951 w /Power Link
CRANKSTEL Truvativ Stylo, 2pc crank/BB
TANDWIELEN 22S/32A/44A 4mm thick outer, 4 bolt 104/64mm
TRAP-AS Truvativ GXP, sealed outboard cartridge bearing
PEDALEN Shimano M-520 SPD
VELGEN DT custom for Specialized X430, 24mm w/eyelets, 32h
VOORNAAF Specialized Stout disc, sealed cartridge bearing, high/low flange, 32h
ACHTERNAAF Shimano M-525 disc, 32h, alloy QR
SPAKEN DT Swiss 1.8mm stainless, alloy nipples
VOORBAND Specialized Fast Trak Pro 26x2.0", 120TPI, aramid bead, dual compound
ACHTERBAND Specialized Fast Trak Pro 26x2.0", 120TPI, aramid bead, dual compound
BINNENBANDEN Specialized Ultralight 26x2.0", presta
ZADEL Specialized BG Rival, hollow Cro-Mo rails
ZADELPEN 2014 butted alloy, black, 30.9 x 350/400mm
ZADELPENKLEM 7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
OPMERKINGEN Protective clear coat, derailleur hanger, reflectors, owners manual
Reacties zijn altijd welkom !
specificaties:
Laatst gewijzigd door rexer op za 27 jan 2007 22:34, 1 keer totaal gewijzigd.
- Rijdt met: Stumpjumper Comp 2007
Re: Specialized Stumpjumper Comp 2007
rexer schreef:Vandaag eindelijk mene nieuwe mtb besteld bij de fietsenmaker
specificaties:
'k hem just dezelfde maar in 't zilver sinds half augustus....ondertussen een 1000 km mee gedaan en ne supercoolen bike....het beste eraan vind ik de fox vering. heb ne 15.5" voor 1m70, snel sturen, .
- rexer
Misschien dat ik ooit wel eens een vaste vork uitprobeerkiwi_x schreef:ben je niet vergeten te promoten arne ?daelman schreef:prachtig fietske...
Vaste vork en je fiets weegt 1 kilo lichter
Dan is hij idd lichter en sneller, maar heb je dan niet veel comfort verlies? Vooral dan over boomwortels enzo ?
Maja voorlopig blijf ik bij dit Misschien dat ik hem binnen x maanden wel is wat upgrade als ik zin heb om een bepaald onderdeel te hebben
Ik wou dat het al zaterdag was
