Specialized Rockhopper
- DoctorEvil
- Rijdt met: Rockhopper '05 Disc
Bericht door DoctorEvil »
Aangezien er nog geen thread bestaat voor deze fietsen, maak ik er zelf eentje. Ik heb een Rockhopper Disc 2005, en ben er zeer tevreden van.
Wie er ook eentje heeft, of tips/tricks/problemen te melden heeft: hier is de plaats.
- DoctorEvil
*FRAME :A1 Premium Aluminum, disc only, double butted front triangle with 3-D box gusset, reinforced disc mount, externally machined HT, forged alloy drop outs with eyelets and replaceable derailleur hanger
*FORK :Manitou Axle Elite, 100mm, Fluid Flow damping with adjustable rebound, alloy steerer , Black Nitride coated 28.6mm Cr-Mo stanchions, Mag Disc Only lowers
*HEADSET :1 1/8” threadless, black steel cups, loose ball bearings with seals
*STEM :Alloy 10 degree rise, forged and TIG-welded, 13/15”: 75mm, 17/19”: 90mm, 21/23”: 105mm
*HANDLEBARS :Alloy, 38mm rise, 9 degree sweep
*TAPE / GRIPS: Specialized double density Kraton
*FRONT BRAKE: Shimano M-525 full hydraulic disc, Post mount, 6” rotor
*REAR BRAKE: Shimano M-525 full hydraulic disc, 6” rotor
*BRAKE LEVERS: Shimano M-525 full hydraulic disc
*FRONT DERAILLEUR: Shimano M-510 Deore, 34.9mm clamp, bottom pull
*REAR DERAILLEUR: Shimano M-570 LX
*SHIFT LEVERS :Shimano SL-M510 Deore
*CASSETTE :Shimano HG-50, 9-speed, 11x34t
*CHAIN :Shimano HG-53
*CRANKSET :Shimano Deore, Hollowtech arms, 13/15”:170, 17-23”:175mm
*CHAINRINGS :44s/32s/22s
*BOTTOM BRACKET: Shimano, BB-UN25 68x118mm
*PEDALS :1-piece alloy body and cage with clips and straps
*RIMS :Mavic XM-117 disc, 26”, 32h
*FRONT HUB: Specialized, Disc 32 hole with alloy QR
*REAR HUB: Shimano M-475 Disc, 32 hole, loose ball bearings, alloy Q/R
*SPOKES :1.8mm (15g) black stainless, brass nipples, L260/R263mm front, L261/R260mm rear
*FRONT TIRE :Specialized Resolution Sport 26 x 2.0”, wire bead
*REAR TIRE: Specialized Resolution Sport 26 x 2.0”, wire bead
*TUBES :Specialized, schraeder valve
*SADDLE :Specialized Body Geometry Sport MTB
*SEAT POST: Alloy 30.9mmx350/400mm, micro adjust
*SEAT BINDER: Alloy QR, 36mm I.D.
*NOTES :Chain stay/seat stay protector, derailleur protector, reflectors, owners manual, clear coat
Laatst gewijzigd door DoctorEvil op wo 22 mar 2006 17:25, 6 keer totaal gewijzigd.
- DoctorEvil
Ah, excuseert, dacht dat het voor 1 soort fiets, 1 topic was. Zodat alle goede punten, slechte punten, tips, ervaringen e.d. over 1 soort fiets gebundeld worden. Zou anders ook handig zijn hé, voor iemand die op zoek is naar een fiets. Maar oké, ik zal deraan denken. Zal ook proberen fotooke op de site te krijgen
Laatst gewijzigd door DoctorEvil op wo 22 mar 2006 17:09, 1 keer totaal gewijzigd.
- DoctorEvil
Bij deze:
De fiets staat volledig standaard, zoals op de foto; voethaken inclusief, maar das niemeer voor lang
- DoctorEvil
Elk zijn gedacht é, de kleuren waren de hoofdreden waarom ik deze gekozen heb . Zo een kenner ben ik dus hehe. Maar in het echt komen de kleuren wel meer uit dan op deze foto. Heb wel enkele echte foto's maar deze zijn met gsm getrokken, dus nie van zo'n goeie kwaliteit als deze foto.
- MARTINI
- Rijdt met: Alan, Trek, Empella, Scatto, Giant
toch bedankt! maar als ge ooit eens foto's trektDoctorEvil schreef:Elk zijn gedacht é, de kleuren waren de hoofdreden waarom ik deze gekozen heb . Zo een kenner ben ik dus hehe. Maar in het echt komen de kleuren wel meer uit dan op deze foto. Heb wel enkele echte foto's maar deze zijn met gsm getrokken, dus nie van zo'n goeie kwaliteit als deze foto.
met camera zend ze dan a.u.b. een naar mij é
greetz MARTINI...
- DoctorEvil
