Specialized 2018
Specialized 2018
Epic 2018 - met ingebouwde cocktail shaker.
42mm offset terwijl alle merken met een slacke vorkhoek 51mm gebruiken?
"Let’s be honest with each other—XC riding and racing has changed. Gone are the race courses that resembled walking paths through the park. In are sections of trail that could be mistaken for an enduro track. We knew we had to address the sharp, often intimidating ride characteristics of XC bikes, so everything was thrown out the window and we started from scratch.
We increased the reach to make for a longer, more stable front end. To keep the rider position consistent with what we have today, we shortened the stem length, which also makes for quick handling. The head angle, meanwhile, was slackened by 1.5 degrees to create an aggressive 69.5-degree angle. Those two changes combine to create a bike that's much more confident at speed and descending through steep and rough terrain. But you're probably thinking, "That slack of a head angle will make a cross country bike floppy and slow, right?" Wrong. The bike and suspension team tested dozens of tuning setups and fork offsets until settling on what gave us the best balance of stability and snappy handling, leaving you with a 42mm fork offset. You can have your cake and eat it, too."
- Conrad
- Rijdt met: Specialized S-Works Epic 2021
Re: Specialized 2018
Amai, het is allemaal glitter & glamour bij Specialized .
- s-biker gert
- Rijdt met: S-works epic 2018, Scott scale RC 29, Specialized s-works HT
- bip bip
- Rijdt met: Scott spark RC 29er,Scott scale 29er expert,Rigid 29er Chinees,Cervélo Aspero gravel
iemand al iets gespot van de 2018 levo turbo modellen ? 't vrouwke wil er ene maar voorlopig nog niks kunnen vinden of er iets verandert tov de 2017 modellen.
grt,
bip bip
grt,
bip bip
- Real Epic '89
- Rijdt met: Isn't dead.
Bericht door Real Epic '89 »
Goede stap van Specialized om naar een kleinere sprong te gaan op hun vorken.
Ik rij al jaren bewust met een kleinere sprong. Is stabieler op hoge snelheid en beter te plaatsen bij lage snelheid. Ik ben het nooit eens geweest met Gary....
- R1ALAIN
- Rijdt met: Niner AIR9RDO-NINER AIR9-Scott Spark RC900(STOLEN !)-SCOTT SCALE RC WC
Waar ?
SBIKER schreef:Vandaag ook de nieuwe scott spark rc world cup gezien
Ziet er ook niet mis uit
Zal een moeilijke keuze worden
T'ja en daar hebben ze dan 20 ingenieurs voor nodig om vast te stellen dat BSA zo slecht niet is héfunkstar schreef:Lang leve BSA.
Wel ne ferme velo.
